Couldn't you do something to the axle or the point that the e-brake is at to make it so that the front keeps rolling when you press the e-brake?I think it is the same as my Fireteam E-Brake.
If it is, it is not much of a rear brake. When you use it, it locks up all four wheels making it hard to slide the rear out. But it does stop the car fast as all of the wheels lock up.
It is interesting but was over sold if you ask me. Wish I could modify it to only lock up the rears.
The handbrake brakes the main driveshaft in the rear of the car. If the rig uses a center diff the front should still be able to spin, albiet maybe not quite as freelyCouldn't you do something to the axle or the point that the e-brake is at to make it so that the front keeps rolling when you press the e-brake?
That would be interesting. I want pics!Only person I know that owns a Felony converted it to nitro
Sorry as I missed this.Couldn't you do something to the axle or the point that the e-brake is at to make it so that the front keeps rolling when you press the e-brake?
I feel that that would be pretty easy to do. I mean it has plenty of space since the center diff is right in the middle. I just saw on YouTube someone put 2 traxxas 3.3 engines in a felony. Seemed pretty cool.Only person I know that owns a Felony converted it to nitro
I'm assuming the handbrake is engaged via a 3rd channel botton on the radio and I'm assuming the rig uses a center diff. If those two assumptions are correct then if you stay on power while hitting the handbrake the center diff should allow power to go to the front wheels while the handbrake manually slows the rear driveshaft.Sorry as I missed this.
That would involve separating the drive shaft from the from axle and a lot of engineering.
I am not even sure how I would go about that. Mayne a joint that only grabs when it spins in one direction? IDK.
This is why they engineered the car like they did and try to over sell it.
