I'm looking for good proline springs
brissak77
Hello everyone
I just bought shock absorbers for trx4 but the springs supplied with the proline shock absorbers (big bore) are too soft do you know any manufacturers who can provide me with very good ones hard enough to support the necessary weight
Proline big bore 90/95mm PL6343-00Thks. Somebody told me that all the springs from proline are apparently too flexible
There are other springs
https://www.amainhobbies.com/proline-big-bore-scaler-shocks-spring-set-pro6343-02/p1158030
But what's happening that you makes you think they are too soft, are you looking to lift the truck? Did you set the preload (crank down the collar)?
Usually soft springs are good with crawling. You get a lower CG and some decent flex. It can make the axles less stable under load though. The springs set the height and the dampeners set the rebound.
