I just traded for a T-maxx with the dynamite big block conversion but it came with no motor so I ordered a .27 Sirio pro from my LHS. I am new to the maxx and just had a few questions. I have taken it apart and put it back together cleaned, lubed, and replaced screws.
1. One thing I noticed was that the out drives coming from the front and rear diff wobble. They arent solid in the diff cases. I took the diffs apart and everything seemed fine. Is this normal for them to wobble?
2. I took the tranny apart and all the gears are metal except the two center gears. Do people usually replace all the plastic gears or just the main ones?
3. I ordered the Proline Power Stroke shock set and plan on using them for racing. Any one have exp. with them?
4. Whats a good start for a spur gear clutch bell set up for racing?
I'm sure I'll have more question when I get it running because the guy said he thinks the 2 speed tranny needs adjusting?
thnks for you time
thnks for you time
