Hello all, I am having some trouble tuning my hpi rs4 3 evo+ And hoping you guys can help! To note this car has been ran in and ran around 4-5 tanks of fuel.
Ok, so the car sits in idle, fine, and when I give it throttle to pull away the engine cuts out. I can get around this issue by increasing my idle trim on the remote, until the car starts moving forward slightly, now I can pull away and drive the car about.
So I can drive about fine at low revs, but sometimes when I put full throttle the engine just stalls and cuts out! If I hold the car up and rev it, it won't cut out.
So I'm guessing it's an issue with HSP either being too rich or lean, I have both high speed and low speed needles at factory setting, and making slight changes in small increments BOTH ways, makes no difference.
I'm guessing I need to go to an extreme setting in some way but I'm scared to go way too rich or way too lean, incase I damage the engine or the needles I'm the carb.
Every car I see online seems to have the needles in quite far where as mine are flush with the carb.
Thanks
---------- Post added at 10:55 PM ---------- Previous post was at 10:53 PM ----------
Also, idle needle is at factory setting.
Thanks
