Messed with the carburetor on my mgt4.60 little and now it won't shift
What happened?
What happened?
What happened?
Thanks for the video, but I think it's in the tune and not sure witch way to goIf the engine is too rich & lagging power ,your trans won't shift ,however ,you should not run your engine so lean
to make the trans shift ,you need to find the balance of the tune an then the shifting point!
So ,find your tune that your engine is happy with ,then find the adjustment screw on trans then back the screw
up about an 1/8 of the turn ,when you back the screw off ,you are releasing the tension off the shift paw to
allow it to shift sooner!
I have a vid on how to do it!..
You use FastEddys in nitro motors?Too rich & laggy will cause the trans to not shift ,a leaner tune will create higher rpm's to activate the shifting ,remember ,
the 2 spd clutch hub works off of centrifugal force to engage ,so a laggy engine is not going to do it!..
Also if your engine tune is walking all over the place an won't hold a tune ,especially on an older engine ,chances
are ,your carbs needles o-rings are bad an leaking causing unstable running conditions!
i had a feeling it was from last years contest. just figured I would ask as sometime this year I'm pulling my nitros out, and happened to see that.No ,in fact ,I never had to replace an engine crankshaft bearing ,those Fast Eddy's are for the 8.0 running gear an
actually won them on this sight from a drawing!..
I think your balls may be dry and rusty.No ,I think it was 6 or 7 years ago..
