Hi all..
I just wanted to share this with you.
I have done a dual tank mod for the T-Maxx. I allready made it for the Savage, but it is not so much of a challenge as doing it for the Maxx.
I have used the Hayes 2oz. headertank (usually used for helis and planes) and placed it where the reverse dervo normally would be. I allready did the FOC so I had the room for it.
I then simply made a bracket from 1.5mm alu and ziptied the headertank on to it. The Zip ties is some durable little devils normally used for industrial work (yes there's apparently different kinds of zip ties. A friend of mine advised me for these)
I hope you are able to see how I mounted it on the pictures. If not, then I will try to answer alle your questions.
Edit: I changed the image size to 640x480. I forget I use 1920x1200 on my Inspiron-8600
Regards
Regards
