Hi There,
Got a HPI Savage 25 that I’ve not run for several years and I’m just starting to take it out again.
Noticed that when the tyres are on the ground the steering does not turn very much but when lift off the floor it turns perfect.
Under load the steering motor seems to be very strong but has I mentioned not with the wheels on the ground.
car is fitted with a new battery pack that is actually rated at 6800 mh so should be more than enough battery power.
All three Servos were replaced years ago with strong non HPI units has was a reverse gear and a chrome tail pipe added.
I’m not sure if the current steering operation is normal when car is not moving forward or if I need to take a look at the servos again.
Can somebody maybe confirm pls?
Thanks in advanced.
Les.
Thanks in advanced.
Les.
