Start by getting everything running perfect, so you have a solid base to improve on.
Get your gearing right. Bigger spur gear or/and smaller clutchbells will give you better acceleration, Smaller spur gear and/or bigger clutchbell will give you more top speed. In both cases you'll find that it's not a good idea to go to extremes, since a very low gearing will make your wheels spin wasting power (besides no top speed), and an extremely high gearing can give very poor acceleration & lower top speed due to insufficient engine power. It's a matter of finding the sweet spot, depending on how and where you run your rc.
TIRES! The most important thing for a stadium truck, since you don't have the benefits of 4wd you'll need a good set. There are different types for different surfaces. I found the Proline Gladiators to be good all rounders for the rear on my rustler, decent on grass, hard pack and street runs.
Assuming you still have the stock t-15 engine I would recommend a tuned pipe for it and using 25% nitro fuel. 30% on that mill will shorten it's life considerably and won't give you that much extra power, not to mention that 30% nitro fuel is more expensive.
Hope this helps!!
