Hi guys jusymt wanyrd to ask if a HPI T3.0 Nitro Engine 18 15 RC will fit in a rush evo I did ask would mt2 engine fit but fancy this engine any help would be great cheers
All of them have the same engine mount bolt pattern ,so they should fit ,although ,there maybe a slight
difference in the crank shaft lenght ,that issue can usually be addressed with other parts & adapters!...
More than likely it will fit ,the parts are easy to find ,what might happen or change would be where the clutch bell
gear meets up with the spur ,it depends on if you can adjust that with the engine mount!
Usually the engine manufactures give the demensions of the crank shaft in the engine manuals or displacement on
the sales adds of engines!
