jack_mcgill
RCTalk Racer
maybe your horn is out of center... it might just be a rigging problem ....also you can use the alternate horns they give in the kit ,they have more adjustments...just remove the carb control rod and the brake rod then chek the travel of your servo...in neutral it shoud be about at the middle of the travel..or you cam ajust the horn how you want it...you can also adjust the carb rod lenght by spinning the rod end
....there is a lot of setting you can change on those... chek it out or get someone to look at it before spending 170$ on it
for the ride height ..there should be spring shims you can use in your kit..up to 1/4 inch
