Hello everyone,
I'm from Cambridgeshire and on a whim started looking to get in to nitro RC after being out of the electric RC scene for a while.
My interest started a few weeks ago when a Nitro buggy showed up on a Facebook buy/sell site for what looked like not a lot of money, it was advertised as a HPI Rush running but with no radio gear.
After buying it I soon realised that it wasn't a Rush but an early Firestorm with an Acme engine and needed quite a lot of work and money spending on it. After buying some Nitro and a new glow starter, you could get it started but it wouldn't idle and the idle screw was bent, after deciding that fixing this plus new tyres plus new front wheel bearing would start adding up I decided to pass this car on and look for something which would give me a better introduction.
I started trawling eBay and came across a Firestorm 10T on auction advertised with a stuck pull start, I checked around for prices of these but the only thing I saw was an Amazon advert for £300 pound, with not a lot of time I punted some money at it and won it for £205. After winning it I found that you can actually buy them cheaper brand new from model shops but you live and learn :?
Anyway I wanted somewhere to share my experiences and maybe do a bit of reading an get some assistance and ended up here.
I've since taken delivery of the car and it was clear the seller knew it wasn't the pull start that was stuck as they'd taken it off of the car along with the heat sink, both were loosely replaced with the incorrect screws.
I've taken the pull start off and it moves freely when off, it doesn't appear to be flooded since the heat sink and glow plug etc had been taken off, you can't crank it manually by hand it's stuck solid, you can move the piston down slightly and then crank it back up to where it's stuck.
I'm not sure what's wrong with it so I'll go find the appropriate section of the forum to ask for further advice but i'm guessing it's going to need stripping right down maybe?
This has put a bit of a damper getting in to the hobby since it's been a few weeks now and I haven't actually driven a car yet but onwards and upwards as they say, I'm sure it will be even more satisfying to see this car moving now than if I'd bought a new one from the start.
Apologies for the length of the first post and if you've made it to the end good work
