Hpi baja 5b problem please help.
cmzm
Hi guys, I upgrade the motor on my baja 5b from 26cc to 30.5 since I put the big motor on it the the c clip that holds the spur gear on place keeps coming off.
Any better spurs out there something that use a screw instead the clip thanks for the help .
It's quite possible that while taking off your spur gear you stretched the e clip causing it to not stay on. My suggestion would be to get a 6mm e clip from home depot that hardened steel. The part number for .the HPI one is Z106. Here's a link to the page at home depot if it helps:
http://www.homedepot.com/s/6mm%20e%20clip?NCNI-5
If you don't have $60.00 to spend on titanium out put shaft this Kraken hi strength stainless steel one works great for me in my basher
http://www.davesmotors.com/tr890_3.html
