How to Support Bell Crank Shafts on Team Associated Pro4 SC10 / Rival MT10
Lumikko
RCTalk Champion
Military Veteran
The bell crank shafts on the Pro4 SC10 / MT10 are 5 mm plastic rods that seem to have some support at the top but the amount of flex tells otherwise. I took out a caliper and verified that the screw heads have a sloppy fit to the holes below the main chassis.
A simple and cheap fix: heat-shrink tubing to thiccen them up!
This probably doesn’t solve an actual problem but feels good to know it’s there.
i make a carbon fiber brace and use a longer screw
Sounds solid! Do you have pictures of the brace? Did you modify something else as there seems to be little space between the bell cranks and chassis?
