How to check a receiver
harley06
How can you tell if a receiver or transmitter is bad. I put a Tmaxx together hooked up the electronics and nothing worked. I have fresh batterys checked for broken wires and still nothing.
Thanks
First off, welcome to the forum. :dance:
You'll get more responses to your question if you post in the "Traxxas T Maxx"
section of the forum.
Are you using a Traxxas radio system? In a nutshell,
If you're using the old TQ3 system, you probably have a damaged frequency
crystal. (on Traxxas TQ 27MHz AM radios)
If you're using the TQI 2.4GHz system you probably need to re bind the Tx and Rx.
http://traxxas.com/support/How-do-I-bind-transmitter-receiver
http://traxxas.com/sites/default/files/6507-6508-6509-TQi-Manual-120130.pdf
Good info in the above post.
This thread is fine here, since it's a Rx, Tx problem, but I'll move your "Reverse only" thread to the Traxxas forum.
