hugo said:
Thanks for all the help guys. I truly appreciate it. I'm looking at about 499. for the .46. Which leaves me around 250. Don't know if I can do it?
That seems pretty steep for a 4.6 kit. I got mine for $350 at Ultimate hobbies about $370 with tax. Skill wise, this was my first rc car ever I stumbled on a few places wondering if things were ok, but, the assembly as long as you read the instructions, you can fly through it in about 2 days, or 1 long day (not including paint).
What I think was the biggest pain in the ass in the kit:
1. Threading the turn buckles.
2. Getting the exhaust spring to not pull the pipe and gasket out of whack. (mounting the motor and pipe to the body before attaching the exhaust to the motor with the spring helped me alot.)
3. My flywheel collet needed a shim.
4. Threading the brake linkages may take a while.
5. And if you dont know, over tightening the dual disk brakes on installation will cause the transmission to feel like its catching in a certain spot(note make sure you install the brake piston and that it doesn't fall out when you put the pads and disks on, It fell out with me after moving forward only to noticed it later and take everything apart.)
6. Having a dog that eats your parts!
And as someone said before good tools are a must key being proper sized screw drivers or you will strip the head and a set of small set of deepwell metric sockets speed things up but are not needed.
But then I'm a total n00b so
