take the glow plug out and spray some after run oil or some wd-40 in the glow plug hole. just a short burst. then press the EZ-start button for a few seconds with the truck upside down. take the air filter off and spray a short burst in the carb at WOT. and if you want you can take your back plate off and put a few drops on the bottom of the connecting rod where it goes on the crank. hope this helps.....
