revoracer322
RCTalk Qualifier
Hey guys like the title says how do i make the front tires spin faster than the back? also how do you build shocks with internal springs? Thanks!
To make the front wheels spin faster then the rear on your rig you will need to get under drive gears for the rear axle with is what I run http://www.rcpcrawlers.com/product.php?productid=1420&cat=29&page=1 or there is a over drive set you can put in the front https://www.tcscrawlers.com/Axial-R...-for-Axial-AX10-Scorpion-AX30401-p-17253.html , either way the front will spin faster then the rear, you might also look into a faster motor that will give you a little more wheel speed over all like the Integy 35t motor they can be found for around $20 http://www.rcplanet.com/Integy_Matrix_Pro_Lathe_Motor_p/intscm3501.htm this is the only thing integy makes that i would put in your crawler, doing this will make it easier to make sharper turns and help to get rid of torque twist.
Thank you! What motor do you run in yours?
He's running a 35t integy.
Your running a rooster arent you Revoracer? So you will only be on 2s if you run lipo, so a 35t is definatly something you will want for some wheel speed. If you get a chance to step up to a mamba or sidewinder or HH, then you can go to 3s wich is like night and day over 2s....Or, with the HH (and mamba, even though it doesn't say you can) you can go to 4s for some crazy power!
