NCNitro said:It will still work. You will just have to remove the bellcrank for the throttle linkage and hook up the linkage like an old style maxx. The shaft will need to be cut, get an AE cut nut, thread it on to the shaft, then use a dremel with a cut off disc to cut the shaft, remove the cut nut, bolt on you clutch nut, cluth, and clutch bell, and drop her in.
zandor22 said:and the e clip your talking about you won't need it on that mill.The crank shaft should be threaded.so you need a machine screw and some clutch shims..
