nitro_desert
RCTalk Champion
i have a hyper 8 mach .28.... you know when you lift the car off the ground and wot it the car screams soo loud! how can i get it to really high rpm on road when i wot it?? it will look so great!
All silicone diff fluid is a "LOCKING" type fluid. It is not lie JB welding it permanent. Each one has a different weight to give it a more locked or stiffer feel. The heavier it is the more stiff and vice versa. Tuners use it to allow more control in the rear, front, center or all three if you have a three diff set up.why do i want to lock up my diffs????? what nitro % do you recommend?? and hey does anyone know the factory tuning for the engine? i can't tune it! and it wont stick to a tune? whats up with it?
anything else other than foam i can use?
Stopping the engine by plugging up the stinger of the pipe shoves fue in your crankcase then it shuts off. If you leave this in there for a llong time, it will gum up and make starting hard. The next time you start it, you should clear it out with a few quick blips of throttle..only problem is i can't see the lsn soo well so i can't know when its flushed out.. i can flush out the hsn..haha i think I'm an expert on hsn tuning but a noob at lsn
and hey it seems like my plugs keep going bad every single day of running! i run the buggy 2 tanks each day and on my last tank before the nitro is finished i block the pipe so the engine would stop... so when its cooled down and i want to start it again(i use a bump start) the engine will start up a bit then it shows no sign of life..i open up the plug and test and it wont light up...what causes that? it only goes bad when i turn off the car!
