Hot Bodies or HPI?
Saint
which you reckon is best?
and does anyone know if the HPI bodies will fit the HOT Bodies cars as they have more bodies to fit an look better, thats in case ppl reckon the hot bodies are better!!
want one of the nitro touring/rally ones they do .16 engine not 100% clued up on R/C cars just wondering what ppl reccomends
Switching bodies from one manufacturer to another is ok as long as it's the same size. if you have a 1/10th car (200 mm) make sure the body is made for that. if it's a 1/12 buy that body size.
Remember, not all markings on the body will coincide where your body posts are. What I do is cut out the excess plastic except for the wheel wells then I do a test fit on the car (take off the antenae) and mark the body posts as well as the stinger, with a permanent marker. Then make the holes and mount the body. Once the body is mounted, I can make the markings for the wheel openings. It's just easier that way since it's harder to make the markings for the cuts after the body is painted.
Originally posted by Diver6127
Switching bodies from one manufacturer to another is ok as long as it's the same size. if you have a 1/10th car (200 mm) make sure the body is made for that. if it's a 1/12 (190 mm) buy that body size.
12th scale cars are not 190mm.
200mm bodies are for gas cars and 190mm bodies are for electrics, generally.
Ok, I stand corrected ... but point being made was stay with the size when going from make to make
