heres what steve pond (the guy that dynoed the V-spec at 2.94hp with stock plug, shims, 9853 pipe and 30%) said:
"The last time I ran the engine, which was about 85 degrees and pretty humid, I ran the main needle at 2-1/4 turns open, mid-range was flush, and the low-speed was 3-1/4 turns open. You must set the low-speed needle when the carb is fully open. Otherwise threading the needle in until it stops will just cause it to jam in the nozzle and push the carb open. I'm not a big fan of going by needle settings however, because the conditions, fuel, glowplug, air filter and a few other things will all factor into the ideal needle setting. If these settings help get you in the ballpark, that's great, but don't rely on them for your settings because your conditions might require some adjustments."
the more fuel I've run thru my V-spec the cooler it wants to run. i cannot tell you were my needles are at, as i tend to jsut tune in a engine and not pay attention to how many in or out turns i am. i can say that my first performance tune after breakin of about 4 tanks the engine wanted to come off the track after a 20 minute main at about 240*, now having not touched the needles and with consistant weather since that day the engine I've seen it come off he track at around 195* with just a little over a half gallon thru it. with that i lean it out just a little so it stays at least above 200*.
tuning for performance with this engine is a little different, as at relatively low temps it puts out more power than any other engine I've ran. some may end up satified with the power from this engine and decide to temp it and it comes out 260*, but for me after driving it around the track and satified with the performance and temp the engine, it comes in at only 205* or so now. i can only imagine how much power it would have at around 260* now, honestly more than i could handle. too bad i smashed the crap out of my pipe yesterday, so i wont be racing tomorrow.
