HJ807 with GPS support
sync
hi everyone,
Background:
I'm very new to RC stuff, but know how to use a soldering iron ;)
Overview:
I'm wanting to have an RC boat with a self-righting hull for the purpose of fishing and taking the line out to see from the beach or off the rocks fishing
and have narrowed in on this HJ807 https://vi.aliexpress.com/item/1005007088260067.html
Problem:
By default this model doesn't have GPS so unable to self return home when lose of signal or lower power
Proposed Solution:
i'm thinking of replacing the mainboard + controllor to something like this
https://vi.aliexpress.com/item/1005006330086692.html
but have a few questions as i'm not too technical with the RC stuff
this is the specs of the mainboard
few questions i have are....
1. the battery supplied with the boat is a 7.4v, would this be not suitable for this mainboard?
2. the default motor on the boat is 540, can it not be used with this mainboard, if connected up what will happen?
key focus is not to replace the motor as the place for them would be very tightly fitted already,
thanks
This is something maybe @Greywolf74 could help you with. That mainboard looks to have decent power output. The boat has a 540 motor in it, there are 540 motors out there that can handle 4s, which is 16.8v. And you can possibly find a 4s battery that will fit in the boat.
Looks like a fun project.
Welcome to the forum!
Can't wait to start, but don't want to over spend, the misses watching my back (I mean the CFO says I need to come up with a proposal so she could release the funds for this project)
So you saying that mainboard is no good with the default motor?
If you run that on 3s power, I am betting the stock motor would be ok. But that depends on the specs of the motor. The kv rating and motor construction will be what limits what the motor can take. If you take the kv rating of the motor and multiply it by the battery voltage you will get the motor's RPM that it will be turning. Some motors can handle upwards of 60k RPM or more. That being a cheap brushed motor, which likely has bushings instead of bearings, 30k might be a bit high for it. So it may be a crap shoot. But I am betting the limiting factor ALas far as power input on that boat is its ESC.
But nice 540 motors can be had fairly cheap. And it should be easy to find a different one that fits, and handles the power needed to run the mainboard you are looking at.
hi everyone,
Background:
Overview:
Problem:
Proposed Solution:
You would need a Step Up Converter to take the 7.4V and boost it to 12V. LINK
It should drive the 540 motor but there are some considerations.
  • Motor Current Requirements: The primary concern is whether the speed controller can handle the current draw (amps) of the 540 motor. Since 540 motors are typically smaller than 775 or 997 motors, they usually draw less current. If the speed controller is designed to handle the higher current of 775 and 997 motors, it should have no problem running a smaller 540 motor as long as the current draw of the 540 motor is within the controller's rated capacity.
  • Voltage Compatibility: Ensure that the voltage range of the speed controller is suitable for the 540 motor. Many 540 motors are designed for lower voltage, often between 7.2V and 12V, whereas 775 and 997 motors might be used with higher voltages. Check the voltage specifications to make sure they are within the operating range of the 540 motor. (This would be achieved using the step up converter)
  • Throttle Response and Control: The speed controller is probably optimized for larger motors, so if you're using it with a smaller 540 motor, you may find the throttle response or sensitivity is not as smooth or precise as with a controller specifically designed for smaller motors. However, this is usually not a major issue in most hobbyist applications.
thanks for the thorough explaination @Greywolf74
based on my understanding now...
would this be a better board for my use case?
https://vi.aliexpress.com/item/1005006854756005.html
Seeing the boat already comes with a 7.4v battery so shouldn't need the recommended step-up converter if using this board
but again not sure on the motor now as the boat has 2x 540,
i'm purly guessing here that 2x 540 would be fine as i'm only supplying a 7.4v battery and not a 12v
S
S
That one only has 10A. I think you'd burn that one up with the current a 540 is going to draw from it, even in a boat. Just guessing. The other one looked better suited though.
S
You need to see what motor is in that, and find the wattage its rated at. Then take that wattage and divide it by the battery voltage and this will give you the max amp draw. I'm betting its way higher than 10A
so in conclusion,
with 1st board, I will need to get an additional step converter if I use the original 7.4v battery
As for the motor I could connect it directly to the board
With the 2nd board, it could be burnt out by the motors amp draw
Is this correct?
so in conclusion,
Is this correct?
Basically yes, but I'm still not sure if the 40A max on the first board is enough. Again, you'd have to find the wattage rating of the motor and divide that by the nominal voltage of the battery being used in order to get a rough idea of the max amp draw that motor will create.
may have found the ideal board (i think)
recap given i have a
7.4v battery
2x 540 motors
self-right hull design
requirment
500m rc range
GPS for return home when loss of signal or low battery
i have tried to get information on the details of the motor but no luck... so its a guessing game here
using ChatGPT...
Asked the following question....
Question #1
I have to boat, weigh 2.8kg. Powered by 7.4v battery. Driven by 2x 540 brushed motors powering 3cm 3 fan propeller. Traveling at 7km/h.
What is the current draw and rpm of the motors?
Response #1
To calculate the current draw and RPM of the motors, we need to consider a few factors.
  1. Current Draw:
    The current draw (I) of a motor can be estimated using the formula:
[I = P / V]
Where:
  • ( P ) is the power (in watts) being consumed by the motors.
  • ( V ) is the voltage (in volts) from the battery.
To find P, we need to calculate the power required to move the boat at a given speed.
Assuming the boat is moving at a speed of 7 km/h (which is about 1.94 m/s), we can use the following formula to estimate the power required (ignoring losses for this basic calculation):
[P = F \cdot v]
Where:
  • ( F ) is the force required to overcome resistance (we might estimate this based on weight, but it typically needs drag coefficient and other details).
  • ( v ) is the velocity in m/s.
Assuming a basic thrust-to-weight ratio and utilizing the weight of the boat (2.8 kg), we can estimate thrust needed might be around the weight of the boat, which translates to approximately:
[F \approx m \cdot g]
Where:
  • ( m ) is the mass (2.8 kg).
  • ( g ) is the acceleration due to gravity (9.81 m/s²).
So,[F \approx 2.8 \cdot 9.81 \approx 27.5 , \text{N}]Then,[P = 27.5 \cdot 1.94 \approx 53.35 , \text{W}]
Now we can calculate the current draw:[I = P / V = 53.35 , \text{W} / 7.4 , \text{V} \approx 7.21 , \text{A}]
  1. RPM of the Motors: For brushes motors, the RPM can be estimated with the following formula:
[\text{RPM} = \left(\frac{\text{Voltage} \times k}{\text{Motor Constant}}\right)]
Without the specifics of the motor constant (which depends on the motor design) it's hard to give an exact number. Assuming you have the no-load voltage rating or typical specs for a 540 motor, they often run around:
  • No-load: 20,000 - 30,000 RPM at 12V for small RC brushed motors.
If we consider that:
[\text{Electrical Speed Ratio} \approx \frac{7.4}{12}]This would scale down the maximum RPM accordingly.
A rough estimate might yield:If a no-load is around 20,000 RPM at 12V,[\text{RPM at 7.4V} = 20,000 \times \left(\frac{7.4}{12}\right) \approx 12,333 , \text{RPM}]
In summary:
  • Estimated Current Draw: Approximately 7.21 A
  • Estimated RPM: Approximately 12,333 RPM
These are rough estimates; real-world results may vary based on specific motor characteristics, efficiency losses, and other factors affecting performance.
Question #2:
to keep the current at 10A, what would my propeller size be
Response #2:
To determine the propeller size required to keep the current draw below 10A, we can use the relationship between thrust, power, and current. We will set up the calculation based on the following relationships:
1. Power Calculation
We know that the current ((I)) relates to power ((P)) and voltage ((V)) as follows:
[I = \frac{P}{V}]
Given that we want the current ((I)) to be below 10A and the battery voltage is 7.4V, we can reverse this to find the maximum power:
[P = I \times V][P < 10A \times 7.4V = 74W]
2. Thrust Calculation
The power required to maintain thrust ((F)) can be calculated with the formula:
[P = F \cdot v]
Where:
  • (v = 1.94 , m/s) (7 km/h).
3. Calculate Maximum Thrust for 74W
Rearranging, we can find the thrust corresponding to the maximum power:
[F = \frac{P}{v}][F < \frac{74W}{1.94 , m/s} \approx 38.14 N]
4. Determine Propeller Size
Now that we have the maximum thrust requirement, we can relate this back to propeller size. The thrust produced by a propeller roughly scales with its diameter squared (assuming the same motor and operating conditions). We previously calculated that a 3.8 cm propeller could produce approximately 44 N of thrust.
To find the required thrust-to-propeller diameter relationship, we can set up a ratio of thrusts:
Let (d_1) be the original diameter (3.8 cm) which produced approximately 44 N,
Let (d_2) be the new diameter we’re trying to find that produces up to 38.14 N.
Using the thrust area relation:[\frac{F_2}{F_1} \approx \left(\frac{d_2}{d_1}\right)^2][\frac{38.14 N}{44 N} \approx \left(\frac{d_2}{3.8 , cm}\right)^2]
5. Solving for (d_2)
Calculating the ratio:[\frac{38.14}{44} \approx 0.867][0.867 \approx \left(\frac{d_2}{3.8}\right)^2]Taking the square root:[\sqrt{0.867} \approx 0.933 = \frac{d_2}{3.8}]Calculating (d_2):[d_2 \approx 3.8 \times 0.933 \approx 3.55 , cm]
Conclusion​
To keep the current draw below 10A while maintaining a speed of 7 km/h, the propeller size should be approximately 3.55 cm or smaller in diameter. However, this calculation is a rough estimate and actual performance will depend on various factors including propeller pitch, motor efficiency, and real-world conditions.
by now my assumption is propeller size can't exceed 3.55cm. (all guesstimates here)
the boards recommended by the seller are as follows
RXG12 - https://www.aliexpress.com/item/1005005685446335.html
RXG3 - https://www.aliexpress.com/item/1005006617495908.html
No Model - https://www.aliexpress.com/item/1005002924309678.html
suggestions?
7.4v battery
2x 540 motors
requirment
500m rc range
using ChatGPT...
Question #1
Response #1
  1. Current Draw:
[I = P / V]
Where:
[P = F \cdot v]
Where:
Where:
In summary:
Question #2:
Response #2:
[I = \frac{P}{V}]
[P = F \cdot v]
Where:
Conclusion​
suggestions?
I'd replace the current 540 motors with 540 motors that have known stats, so I could properly calculate the power requirements I'd need.
