Hey what should I upgrade and do to my jato 3.3 I want to upgrade the engine and do some other things but can anyone suggest what I should upgrade on it or update. Thanks heaps
i put a O,S. 21, engine on my jato. it has more power than is useful. but it is FUN. it is a bolt in. DONT put to much power at low speeds, it will rip the transmission gears out. best to go to single speed, trans.
After your new engine drop and pipe I would go straight to your weakspots, your shock towers, A-arms & such. RPM are litterally breakproof and look great. I would suggest the front end first hence thats where most hits occur.
If your wanting a new powerplant instead of the 3.3 than why not the OS .18? Easy to tune, reliable and you should be able to use the 2 speed conversion with it as its powerful but not over the top. Remember if you plan on racing it you will not be able to run the 2 speed as most sactioning bodies dont allow that modification on the racetrack. If your bashing than bash away!!!
