Jus2krazy2007
RCTalk Racer
Alight I'm relatively new to nitro rc just got my savage 21 the end of may but today i was outside and it wouldnt shift into 2nd gear even when i had it lean as i could without burning it up so then i richened back to normal ran it without second gear :depress: kinda boring but then i stopped it by me and it just died it wasn't to hot at all, and it wasn't very cold either it was at the perfect spot (225 F) so I'm lost what do i do it might have something to do with the transmission and if it is ill have to look in the book and do it but i dont think that would cause it to die and a perfectly good temp........... i need help if this has happened to you tell me what you did to fix it. Any help will be appreciated
i took it apart last night and havent really had a chance to put it back together do you have to put the loctite on when the tranny box is apart or can you do it when its on? I'm planning on fixing it today thanks
