Help with Throttle and break rods plz!!!
REMUS
Hey guys, i just purchased an RTR evo 3, And seem to be having problems with the linkage rods that connect the throttle and breaks. The breaks always seem to be on even in nautral, and even when i push forward on the transmittor, The dosent seem to be any movement.
Any diagrams that will show me the correct postions of the rods and settings will be helpful. Thanks
The rods that connect on the throttle and breaks dont seem to be set correct, When ever i start the engine up the cars breaks are always on even when i increase the throttle.
Sounds like you need to adjust the brake lingage a little. With the servo off move the servo to the lowest throttle setting. Once there adjust your brakes until they are no longer engaged at that position but slightly after the servo reverses and starts engaging the breaks. If this does not help post a pic of your current setup, it could be that you connected something wrong or you have your servo reversed.
