Help with starter conversion
BSPOT
New to nitro and RCT so bear with me. I'm wanting to convert my tmaxx (2.5 converted to 3.3) from an EZ Start to a roto/torque start. My problem is the roto start plate I have requires a hex shaped one way bearing and my engine has the standard 3.3 shaped one.
Can I simply get a hex owb and install?
Pic attached
Follow question; if I can get a hex shaped owb, do I need spacer washers and if so what size/how many?
Awesome sauce. I'll bite and get the TRX owb. I've already got the same part as the Redcat part listed.
Many thanks D3MON!
Couple of things regarding this rotostart.
Grease the gears a little before assembling. Don't overtighten, it's easy to do, and the assembly will bind, and the plastic will crack and crumble apart eventually.
Otherwise these rotostarts work really well. I have one in my tmaxx, and one in my drag car. Big weight saving over the EZ Start.
Thanks for the advice johnnydmd. New to the nitro game and would not have even thought about that.
B
