Z
Zoomer
Guest
Just a bit of help is needed.
In picture #1 and #2 look at the brackets that are there. my fron tires are splayed out wards like this \-------/ , and they ride on the inside thread. as you can tell from the worn off tread. I would like to reset the setting back to factory setting to where my tires are straight. I have tried to fix this problem by making adjustments, but I cannot seem to get them right. If any what hop-ups can fix this?
Images #3 and #4 show how my gears are chewed. I lost 2 screws from my spur gear, and it causes the gear to become displaced, so I have not run my car. I also have some how seemed to get my clutch bell, and pinion gear all chewed up too even though they are mtal, the plastic gear is not that bad, just a coule of dings. Should I replace my clutch bell, pinion and spur, or should I just get the screw set for my car, and replace the screws and wait until they are totally SHOT?
