Bad Inferno
Help ! I have been trying to fix a two speed as I thought the engine was dieing when it shifted, however I took the two speed clutch out ie force the thing to only run in first gear and it seems that my engine is dieing at full throttle.
Novarossi .12 pull start in a touring car. The car flames out at full throttle after about 4-5 seconds of running flat out. the car accelerates really well however after about 5 seconds running at full speed it dies.
fuel is 16%
The LSN is set just about flush and the HSN is 3 turns out. Now I thought it made sence that the engine was flooding at full throttle however when I lean the HSN it will "bog" down on acceleration and nearly die, even with the LSN set flush or even 1/2 turn out from flush. Leaning the HSN does not allow acceleration. The mid speed needle is set flush.
I assume that an engine should run at full throtle in first gear, it is running really fast before it dies.
This thing is driving me crazy as I can tune the LSN & HSN for great idle, acceleration and top speed and I can feel the difference in the settings as I adjust however cannot get the thing to run flat out for any longer than 4-5 seconds. I was thinking of setting my trim not to open the carbie all the way however only masks the real problem. I have also installed a new Rossi plug
fuel is 16%
