The normal stroke on the pull start should be no more than 10 inches. If you are pulling the cord further than that, you will snap the spring inside the pull start case. I do not know how much cord is spooled in the TRAXXAS pull start, but I would suggest that you not pull it half way out (unless the halfway mark is less than ten inches...in which case I suggest getting a new pull start with more cord).
