Tmaxx 4909 3.3 has run great for the past year. ran tonight for 5 minutes then THIS HAPPENED.
[ame=http://s75.photobucket.com/albums/i292/dansguns/?action=view¤t=tmaxxrunisue.flv]
[/ame]
Ran great, didnt change anything.
wasn't too hot....
Throtle linkage is still working... carb is opening. I removed the air cleaner... didnt help. Toped off the feul didnt help.
Heres the kicker..... I can hold the throttle wide open and the thing doesn't move.... if I pinch off the feul line..... IT TAKES OFF then of coarse it runs out of feul.
I have not changed anything.. and it ran good for 1/2 of a tank.
Midway through a tank of gas.... it just decided to run like poop.
I took this video after checking all the obvious stuff.
OK because I notice dthat it would move when I pinched the feul line I decided to lean the HSN.....
MAGIC INVISABLE CRASH....must have backed it off. i am assuming the threads are stripped. I turned it WAY WAY WAY in and its back to running nice again. there was no reason for the HSN to have gotten that far outa whack..... must be stripped.
another problem.... ITS INHALING fuel....... 2 tanks for 5 minutes of complaining
wasn't too hot....
