Help, MGT sat for a while
Millera089
So I have a MGT 8.0 1/8th scale I got awhile ago. This will be the first summer I've started it in years.. Is there anything I should do before starting it? And I believe last time I started it it would rev high but not move, what could be the problem of that?
Thanks!
Thanks!
Did you put some kind of after run oil in the engine before you put it away?
An have you tried starting it when you got it out?
1) Check it still has compression.
2) Check glow plug
3) New fuel
4) Check for air leaks in lines
5) Check radio & servos
