help me please losi aftershoock
robroy
cluch went on motor tore my high and low gears replaced cluch in motor new high and low gear new cluch but when i give it gas does not move..dont know what in did wrong can some body help me.:\
Did you make sure the slipper was adjusted properly? If it is then did you make sure the pin in the tranny's output shaft didnt fall out when you were changing out spurs.
how do you adjust slipper i thought it sides in??
The slipper clutch needs to be adjusted with a wrench. I usually tighten them down and then back it off 1/2-1/4 turn. As greywolf stated, make sure you installed the pin that slides through the input shaft. The slipper clutch and spur gear assembly will then slide over that pin.
