Help identifying spare part
Hepher88
Reading
Need some help, not the greatest pictures sorry. So, behind the bumper guard there is a purple metal part that sits in front of where the pins go through to fit the low suspension arms, the metal part sits flush with a hole in both ends for the pins to go through 1st, I crashed the car a month back and broke the low suspension arm but also bent that metal part ever so slightly but it means it doesn't sit flush and so can't get the little e clip on the end of one pin. Luckily there is not enough room for it to come out as the bumper guard is in the way but still not ideal. Any help identifying that part would be amazing, not sure what I'm searching for
That would be an aluminum tie bar. It may be called by other names, but if you download the manual for your car, it should list a part number. Then you can search for that part number and aftermarket ones should show up as well. For what it's worth, a hammer should flatten it right back out, if it is indeed what I think it is.
Believe it or not my dad still has the original manual from about 15 years ago ha didn't think about checking it tbh but makes perfect sense. I did think about heating it up and flattening it out but it is so old I didn't want to break it further, would imagine it may crack. I'll have a look and see if I can find it. Thanks man
Hot bodies lightning is what the buggy appears to be. Usually see that plate referred to as a hinge pin retainer. Looks like HB refers to them as "suspension holder":
https://hbracing.com/cars/spare-parts/front-suspension-holder-7075-lightning-series/
Not sure if that's for yours or not.
I had a HB Lightning many years ago, wasn't the best, but also not the worst. Was a decent basher buggy for what I wanted.
This has a lightning 2 in it:
http://www.hpiracing.com/assets/pdfs/parts_id_booklet/92030.pdf
Looks like the part from that manual, C8078 for the front pin holder:
https://www.ooprc.com/product-page/...7075-aluminum-suspension-holder-for-lightning
It is a Lightning 2 RR, about 15 years old tbh but a great basher now I've lifted it a bit for off road. That looks just like the part I'm on about as well thanks! Will check it out
