Hi guys, I'm having trouble with the receiver or the dynamite race guard fail safe. With out the fail safe the truck works fine but when I put it on the dam thing sometime does strange things,like when I turn off the transmitter most of the time it puts the brakes on but 3 times it whent wide open!! good thing I was holding on to it ,other times it will just stop without the brakes being applyed so I turn the receiver off then back on and it will work fine. And then somethimes it works perfect ! Most of the time when this was going on I was uesing AA batts. but just the other day I put a hump pack in and still doing strang poop with that being fully charged. Now comes the part where I get screwed when I got the fail safe I spliced the wire and soldered a half inch more to it so It would fit under the receiver where the 3rd servo would go, then I could put the lid on . I'm sure the solder job is good . Is it in the fail safe or is the receiver going bad and the fail safe is picking this up? I don't know anyone with a fail safe or a receiver that I could swap with to see which one is bad or do I spend another $35 on a fail safe just to find out that is not the problem. Thanks for your time in helping me out with this dam problem!!
