HELP !!! can someone answer this ????
Before Monkey Wrench outright screams... wait, nevermind; I heard it clear over here in CA..........
Dude, you seriously need to calm down, and stick to the one thread. That aside, we're trying our best to help you, even though you're spamming the living daylights out of the board.
Calm down, breathe, and stick to the one thread.
Remember; it's a TOY CAR!!!
redhatman said:
SO USE THE SEARCH BUTTON LIKE EVERYONE IS SAYING... man, I'm already gettting annoyed.
Damn man Is this an oxymoron or what?
Or are you just a dumb as you look?
Your getting annoyed...What did you do to the members here for months on end...
Did you forget.You say poop like this makes me want to come through the screen and punch you Right in the mouth..
search button doesn't help me! :fro:
my engine is flooded... :opps:
I just can't sit here and understand How you can say any thing like this.
Annoyed...Huh..Every time you type.You piss me off...
Next time you decide to post some thing like this.
Think in to the past OK..Or does your tiny brain not relay the messages right?
In FOUR letters hatman ''STFU''
so your engine is flooded.....
that's it?
OMG, i thought you would of had some common sense to check that before you posted mate.
what your doing is :spam:
Ok Let me give some advice here. First off, please don't take your frustration by posting so much in a given time before anyone can read the last post. Second, have you tried to clear the engine out? Have you taken the plug out, turned it upside down and pulled the starter to get the fuel in the case out?Lots of good suggestions so far but try a few things first and then let us know.
Jon
rmune0750 said:
i have no idea what the hell u just said, I'm not that advanced with the technical stuff, u gotta talk in stupid newbie terms....i dont understand ne of that pull the mill or ARO or BDC or ne thing! :OMG:
frustration, anger, path to the DarkSide this is . . .without anger ask:
mill - engine
ARO - After Run Oil, helps to prevent corrosion and lubes inside of mill
BDC - Bottom Dead Center, this is where the piston should be to prevent from damaging the sleeve and/or cylinder, when storing, i.e. not running the rig, this is where the piston should be. Take out the plug-which you would do if using ARO anyway, and give a pull or two on the pull string and watch the piston decend to the bottom of the cylinder.
TDC - Top Dead Center, the place where the fuel/air mixture is fully compressed when the plug fires it causing combustion which causes the piston to be forced to the bottom of the cylinder, thus power to turn the wheels which causes you to supposedly have fun! :banana:
Here's another thought,Pay attention. If you try to understand what is being said then you should have no problems in figuring it out,All the info to get this engine running is in this thread. The onlything i can think of to help you out if you have not figured out what your doing,Is to buy a nitro how to manual or whatever there called. I'm sure if you stop by your lhs they could probablly help you.
thankyou people.
now he should understand how to do it and will not ask anymore questions. :D
and i will not be so bliddy annoyed!
