Taking head clearence measurements is totaly necacary. Taking it out would not be a good idea for a newbie. Very experienced drivers do this because they know what steps and percautions are needed. If the head clearence is ok and the piston isn't kissing the head, then you have to check the port timing to make sure that the engine won't detonate. Timing or to much compression and not high enough nitro mixture can cause detonation as well. As you can see, it is not a small thing to do. It takes lots of time and practice to get the process right.
Save your time and motor and forget about taking it out.
Learn to drive the car really well and then work on performance enhancements.
Peter
Hope this helps
Good luck
