Bash_N_Thrash
I can't tell if its shifting or not. I installed the 2 speed according to the intructions with the kit. Before testing I also removed the carb restrictor. I am testing the car on the street and have about a 200 foot straight area. The car is extremely fast. It seems to have about the same power on take-off as before (with the single speed), but seems to go much faster. I could not hear it shift into 2nd gear at all. I did some reading and some people suggested the tranny might be stuck in second. To make sure it wasn't I turned the adjustment screws all the way in (tight) and ran the car. That should have given me a basis to judge what first gear could do. Then I adjusted the screws out to 2-1/2 turns (factory starting point was 3-3-1/2 I think) and tested the car. I still saw no increase in speed so I continued to loosen screws 1/4 turn each run, untill I was out about 4-1/2 turns. I could not hear the car shift at all. Should there be a pronounced shift like when my T-Maxx shifts? Or is it not that noticeable? Any suggestions? I dont mind starting over if it would help. Thanks.
