nafie
Ok, here is my story. I got a brand new x for christmas from the wife. I live in Maine and had to wait to get some reasonable weather to get broke in and running. So a couple of weeks ago I started the process to my disappointment the steering servo was bad right out of the box! I dropped in a spare I had and called HPI and they got a replacment right out. This being my first nitro I made some mistakes. First, the rotostart battery false peaked and was not turning fast enough and the battery that came with the glow starter was not getting the plug hot enough, leading to some flooding. After a frustrating couple of hours outside in 30 degree weather I put it up drained the fuel and lube the motor. Fast forward to today, I purchased a XTM rechargeable ignitor and charged in for 14 hours. I also picked up a Odonnell TGX1 temp gauge, and a spar plug I havent used yet I think its a r3 oddonell. So today I had no flooding but struggled to keep it running after I removed the ignitor ( it was about 38 degrees here today). i wrapped the head in tin foil and a clean rag for extra warmth. I was succesful in getting the break in procedure done, temps were only in the 120-130 range> was that warm enough? It was a struggle to keep in running after a refill until it got warm enough( i used the throttle trim to help) I then started my tune on the 5th tank ended up with about 1/4 turn on high speed needle only. temps
only got to 160 then my temp gun quit (battery)! tried to finish off my fuel for the day and my owb gave out on the last tank! So tonight I did some reading and began to take it apart. i found the lower corner of the backing plate broke and missing the screw! i thru the owb in some alcohol to soak and craked a beer. this is my first nitro and my first HPI the thing is i am about 50. bucks shy of ordering a apache c1 and i am having second thoughts. I would like some input on temps for break in and owning HPI
