gunslinger686
A lesson learned the hard way,after puting a new set of alum clutch shoes on my mammoth i had a trany cup set screw become loose so i fixed it and i found my carb barrel was not opening all the way so i reajusted the throttle servo arm.OK now my truck and my mill is top notch hooking up hard and 100% of the throttle.The problem is I DID NOT USE MY CHECK LIST forgot to put the screw back in the throttle arm and it came off hooked hard at 100% and hit a tree. I get a F- .The damage was not too bad ,lower front suspension arm , two shock shaft's &some bent part's.All in all the mammoth took the lick real good.Take a little time to check your work,look around your work area for stray screw's ect.
, about 50 yards later, i found the savage upside down after hitting a conrete wall .:marshall:
