gslst2
gslst2
my new lst2 is slipping while driving the moter revs then kicks hard back in already broke 2 diff pins and replaced any advice would be appreciated thanks guys gslst2
Could be a few things. First, check the linkage for the forward/reverse servo at the transmission. If thats good, its most likely the one way bearing for the 2 speed, its a $25 part. If you did burn up the one way, get two because they don't last long.
Strange that you say that. The one in my aftershock has many gallons on it (probably about 5 with an LRP28S3) and it still grabs just fine.
I'd agree with the linkage though. See if it's staying in gear/forward properly and that your hi/low isn't moving around on you. I have an aftershock trans in my with LST2 two speed. The AS trans doesn't have f/r or h/l. Very simple in terms of a transmission.
