texicus
Hi everyone...It's quite possible that I suck at the search function and couldn't find a thread on this, but couldn't find anything...anyway, here goes.
Running a 2.5 T-Maxx. As of a few days ago, the truck won't shift properly into forward or reverse. The servo seems to be working properly and moving the pinion back and forth, and the truck will lightly jerk in the direction its supposed to be moving, but won't shift fully into that gear. I took the transmission apart (removed the casing) and no gears appear to be stripped or broken...it seems like it's a problem with the pinion not fully engaging, but I'm pretty newb at this, so I could be totally wrong...could it also be a tuning problem?
Also...would a forward only conversion fix this, since the transmission would be locked into forward?
Thanks in advance!
Thanks in advance!
