Savage49
Had a problem this weekend i haven't quite figured out yet. My Truck while running if you make a hard left hand turn the engine leans out and jumps the engine's temp up 15 degrees. Then if you turn right it immediatly starts loading up and drops 15 degrees. Replaced all my fuel line with the same amount stock, Rebuilt the fuel tank with new lid spring, o-ring, the pressure tested it at 5 pounds of pressure, no leaks present. It just showed up this weekend and seems to remain constant thru out the tank, no diffrent's if its full or empty. Running mostly the stock setup 2.5r with backplate compleatly sealed, and stock pipe and header. The engine is new only a gallon on it.
Thanks for any help in finding the issue. :boxing: :jk:
DJ :spit:
DJ :spit:
