Fuel percentage tuning??
doosh
Melbourne, Australia
Hey guys i have been using 16% nitro in my truggy i am going to up the ante and finally run on 20% would i need to tune again? if so would i need to go richer or leaner?? thanks
you will need to re tune. because the fuel has more nitro in it would prosume you will be able to lean it slightly. I tend to stick with the same % throughout the engines life. My savvy was run in on 25% and i've never changed it. Even the brand. Different brands contain different oil content. Its what the engine gets used to.
its like the wife makin you a cup of coffee with 2 sugars, then the next day makin one without sugar. You ain't gonna be happy.
Richen the needle just a little bit. It's always good to look for a lower oil content while you're at it.
Ok, if it's tuned good now, then it will likely need to be richened a little. It might be a little rich now, it might be a little lean now, I don't know.
I sure as hell wouldn't lean it like in post #2.
It's always a good idea to richen it a little when adding nitro content, I can say that.
Start back at factory settings and tune for temp and performance. Never just richen or lean an engine because of a nitro % or fuel type change.
So if an engine was running fine on 10% and you switched to 30% you would just set it to factory specs and start there?
Going from 16% to 20% is not much of a jump, but as a general rule most people richen their hsn just a little bit when going to a high nitro.
Yeah me too, no hard feelings guys. I just stated what seems to be the most common advice given on the topic.
