Mickstix
RCTalk Champion
Hey, I've got a question for the Nitro gurus.. On the fuel inlet of the carb, does the inlet have to be lined up with the hole in the tube, or can it be located anywhere? (For ease of explination I'll post pix explainging what I'm tryin to find out)
Here's the inlet and tube (dont know the real names, but you get the idea)
Here's how it goes together with the inlet lined up with the hole in the tube.
But will it also work like this, or will this starve it of fuel? (The tube has a recess where the inlet goes over it, but I dont know if it's enough to let fuel in properly..)
Reason I'm asking is, when it's lined up straight it makes the fuel line route whacky, and is in the way for adjusting the idle screw.. Not a biggy, but if it works all the same, it'll be a little better if I can point the inlet off to the side more.. Thanks for sharing your knowledge!
