Fuel Flow Problem w/ Duratrax Warhead
nitroburna
Good evening all,
I have a Duratrax Warhead that is about 3 months old. When I first got it, I broke it in and it ran great. Now for some reason I cannot get fuel to flow from the tank to the carb. The engine will not prime. I have reset all of the settings back to factory spec with no luck. The engine will start if you pour a tiny bit of fuel into the carb, but it will quickly die once that fuel burns out because no fuel is coming in from the tank. Any suggestions on a fix?
maybe your fuel line isnt connected to the pipe or gas tank I've got a t maxx and one of the fuel lines connects to the bottom of the tank so its kind of hard to see maybe theres on under the tank on the warhead too.
I would imagine that it is a problem with fuel lines, or there is a crack in the tank or tank lid seal.
