geardigger
RCTalk Racer
Not listing it on ebay anymore since it isnt selling there. Here's the description:
This has only been run a very short time (5 tanks of fuel total). As it sits now it does not run but that is only because it has sat all winter and needs to be tuned. Once tuned it will run! I have had it started only a couple of weeks ago. Ran OK but would not stay running (again, needs to be tuned). I am only selling this because I no longer have time to use it or work on it. You are getting alot of extra goodies with this as well! You can see them all in the pictures I have provided below and the list here.
Brand New Back plate Kit (unopened)
Du Bro Med. fuel tubing (new in bag unopened)
GS Racing Pure Silicon Diff. Oil 1000 cps (unopened)
GS Racing Pure Silicon Diff. Oil 3000 cps (unopened)
HPI Pull Starter (does not fit the savage you are buying)
Brand new Motor saver air filter (on truck, not used at all)
Glo-plug ignitor
Roto start charger (not pictured, in brand new shape and works fine)
Traxxas Fuel Bottle (Brand new)
Assortment of diff gears and misc screws and extra one way bearing, original back plate with small chip on one of the backplate screw mounts.
This truck does have the Ofna spider mod done to the rear diff and the uni-flow mod done to the fuel line. The one-way bearing is brand new as well. The roto start tool I am selling with this does NOT work, I believe the gears inside of it are stripped. I am including it in case the buyer can fix for later use. All you will need is a new roto start tool and you are good to go. This is being sold as is and will come in the original box from HPI. (Like I mentioned earlier, all it should need is tuning). It only has 5 tanks of fuel through it so everything it really in brand new shape! Batteries are included and are pretty much new so you shouldnt have to replace those right away.
If you are interested PM me and we can work something out.
EDIT: Asking 300.00
Glo-plug ignitor
EDIT: Asking 300.00
