I recently replaced the right side user and lower control arm and fr.ont diff housing. When I installed and reassembled damaged parts the front wheels were not moving. I found out the the drive shaft cups need o rings. After installing 2 o rings the wheels moved yet not with the force of the rear wheels. Also the drive shaft I showing an indentation about 1.5 inches from front drive cup. As the motor stops after 30 seconds when I test the car. It requires the shutting down of the car for it to start again. If someone has a solution please let me know.
