Front Brakes and rear Brake size comparision?
vwdave
Are the brake disc and pads in the rear brake same size as the front brakes? Wondering how you could use a steel vented disc in the rear also.
Thanks
Nope rear is the same a the jato brakes and mounts on a different hub and uses 2 disc and 3 pads
Yes, they are 2 different sizes, yes you can use a steel vented rear. See below;
Rear disk is from a Jato.
I have been using it for 2 years. No modding necessary. Just swap the disk and the pads.
