Well, in leu of buying a longer DT chassis, I figured I'd futz around a bit with some light gauge steel and my micro-t. I added about an inch to it's length between the esc and rear shock tower.
I did this primarily so I could run micro raminator tires on it with an AAA saddle pack that I made. She won't win any beauty contests, but it sure runs a long time and is fast! May need to upgrade the shocks to some that have oil as I understand they are a bit stiffer and don't do a lot on the stocker. With the added weight mine has, I'm sure they will compress.
Anyway, poke fun if you wish. I enjoyed working on it though. Made it handle jumps a lot better and pretty much killed my wheelie problem. It takes off at WOT now in a straight line and really cooks.
The original with AAA's:
The raminators on the rear:
The extension plate:
A brace on top to keep it from bending on landings:
And for the concourse, really butchered body:
Looks ok from the front though, this is what the cat will see coming at it!
I forgot and left it on last night, so the battery is dead... charging now, I'll try to run a full pack through it to see how long it lasts. Best guess so far is 30+ minutes of cat chasing.
Upgrades:
axles with nuts
bearings all around
Atomic II motor with bearings
ziptie front tierods
raminator tires/wheels
Upgrades:
axles with nuts
bearings all around
JK!!
