FMS FJ40 Installing hardened steel drive shafts.
BigBaja
RC Showcase: 12
NJ
  3. Crawling
  4. Scale Builder
  5. Flying
Since the front drive shaft would probably be ok using JB, I still added a set of metal drive shafts from Injora that fit, so much modifying was done because all the drive shaft connections had to be enlarged the pin that attached the drive shafts had to be made thinner,
I chucked it in a cordless drill,& at the same time used a dremel with the sanding drum, it worked. Not looking forward to when the back wheel shafts go bad like the front did!!!!
Nice Atlas!!! I have the Orange one plus a clear body, that I am not sure what color to paint??
Where do you buy the parts and framework for the Tow part of it????
Build Showcase My FMS Atlas
3
Build Showcase FMS 182 skytrainer
Build Showcase FMS Atlas
3
